TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
Add a leaf or blocks?
Old 01-17-2008 | 11:40 PM
  #21
beastmode's Avatar
Import Moderator
Originally Posted by shep28
Every 2500 I see stand taller than 1500s
thats cause they are... frames 2" taller on em making them sit 2" higher
Old 01-18-2008 | 09:34 AM
  #22
southern98ta's Avatar
they say you get about 2.5" out of ford keys i was thinking of taking out my 2" block and put in a 3" and put in a helper spring. Helper spring should 1.5" and the extra inch of the block should level it out.
Old 01-18-2008 | 10:07 PM
  #23
04BlackGmc's Avatar
10 Second Club
i have 4" blocks been running it for over 1.5 years, now im switching to a AAL due to spring sag caused by the 4" block.
Old 01-21-2008 | 04:47 PM
  #24
BLACKND's Avatar
What all is needed to do an AAL? We just sold our 2 horse trailer and upgraded to a 3/4 horse trailer. The new one is all Aluminum rather than the steel before, but it is longer and weighs more. The load is balanced really well, with the new longer trailer, and squats less than before, but I'm worried about running it with an addition 3000+ lbs of our combined horse weight. This is on a 2006 ECSB Silverado Z71-5.3 HO.
Old 01-21-2008 | 05:29 PM
  #25
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
All it is, is an extra leaf the goes between the bottom factory leaf and the lift block, you dont need anything but the leaf the factory ubolts are long enough to accomadate and extra leaf.
Old 01-21-2008 | 06:59 PM
  #26
beastmode's Avatar
Import Moderator
most of the time new ubolts will come with them though... but like you said factories are good enough
kalikid06
20
10-13-2015 08:37 AM
Pontiac Derek
09-19-2015 02:49 PM
Pontiac Derek
09-18-2015 10:02 AM
BlackGMC
09-09-2015 02:43 PM
