TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
Best lift for a 2wd Sierra?
Old 05-27-2007 | 11:17 PM
03GMC's Avatar
Default Best lift for a 2wd Sierra?
Thinking of lifting the truck a few inches instead of lowering it. Its a 2003 Sierra hence my screen name. Not going to be an off roading truck much just want it a little taller for the street. Going to throw some 20s on it with just a little bigger than stock tires.
My buddy got a leveling kit for his Dodge and it looks pretty good. Looking for a good street ride and a good price.
Old 05-28-2007 | 12:01 AM
BLK4.8's Avatar
rough country 3" lift cost you about $500 shipped to your door
Old 05-28-2007 | 12:21 AM
RandomHero's Avatar
which is a rip off for 3" spindles a block and crappy shocks.
You can get the Pro Comp 7" kit for around $1000 if you look hard enough.
As for the BEST setup....that's hard to say because they make some $10,000 prerunner kits that would blow away any normal travel suspensions.
I would buy the Pro Comp 7" kit, run a 2" coil spacer and a 3" body lift and throw some 37's on there.
Old 05-28-2007 | 01:39 AM
BLK4.8's Avatar
Did you read his post I don't think he is looking to lift his truck to the sky, I had
installed a rough country 3" lift for a buddy of mine a couple of months ago, it
looked the same as the pro comp 3" lift that I installed on my wife's truck two years ago
the only things is that rough country uses blocks instead of add a leafs like procomp had
when they had sold a 3" lift for these trucks, plus the blocks were easier to
install than the add a leafs
Old 05-28-2007 | 01:48 AM
RandomHero's Avatar
Well a leveling kit for a dodge is MUCH different than a leveling kit for a chevy. Dodge 2wd's can fit 33's stock. If he's looking to fit a similar tire as a dodge with a leveling kit then he'll need at least a 7" kit.
Another thing to ask yourself is why spend $500 on a 3" kit when you can get one that will ride the exact same for $450 more.
Old 05-28-2007 | 07:53 AM
White Lightnin's Avatar
Fabtech is known for their 2wd lifts. They are a little more expensive though.
Old 05-28-2007 | 11:44 AM
RandomHero's Avatar
I paid:
$275 for my spindles
$60 for my rear shocks
$35 for my 2" coil spacers
$40 for my block
This was the end result
EDIT- So believe me guys I know a bit what I'm talking about and I'll tell you that you WILL want to go bigger. So just do it right and get the 7" kit
Old 05-28-2007 | 05:33 PM
BLK4.8's Avatar
the rough country kit is only $430 plus shipping to your door will put you around
right under $500 I think he paid around $480
Old 05-28-2007 | 07:30 PM
03GMC's Avatar
I paid:
$40 for my block
Looks good. How much lift is that?
Old 05-29-2007 | 03:12 AM
RandomHero's Avatar
That's supposed to be a 5" but it sat at 4.5" those are 305/70/16's
