best long travel kit
hi everone im new to this forum so maybe someone has already ask this but i would like know how out there has the best bolt on long travel for and 05 gmc sierra crew cab
Custm2500's Rude Friend
BMS products FTW!!! Way better then Camburgs Junk.... check it out
http://www.blitzkriegoffroad.com/index.asp
CST is not bad stuff, But they got a bad rap after haveing some issues when they first put together there longtravel kits for the 99- up trucks. I know the issues have since been resolved but alot of hard core guys feel there stuff Is like fabtech stuff more for looks then actuall function.
after all these answers no one caught the bolt on part???????
none of the mentiond kits are bolt on, they require cutting and fab work
once you go LT you cant go back to stock
camburg is one of the best companies around, why do you guys talk crap?
they have a race tested silvy kit, none of the other kits have been raced on
camburg is the best kit hands down for silvys, just look at the hardware compared to any other kit
the only argument BMS has is that their kit is 100% chromo
and camburgs kit is mild
its not just about material but the design
mazzula's kit is over priced 4500 -6000 depending on exact hardware
camburg is 3800 with tube upper arm
BMS is 3650
install is always extra
BMS is 3650
