Body lift question
Body lift question
Some background before the question: I'm doing a LLY Duramax swap into a 99 RCSB 1500. The LLY radiator support and cooling stack is 2" taller than the gas one, so to get everything to line up properly I'm going to have to do a 2" body lift. I don't want to buy a full body lift kit, as I won't need all of it. Here's my questions:
1. Front bumper - if I run the half ton front bumper with a 2500HD bumper cap and grille, I won't need front bumper lift brackets, correct?
2. Rear bumper - if I run the rear bumper with brackets from the 2500HD donor truck, I won't need rear bumper lift brackets, correct? (looking at the two bumpers side by side it looks like the 2500HD brackets lift the rear bumper)
3. Bed - are the bed spacers the same as the body lift bushings? Or are they solid? I've found that I can buy individual body lift bushings for a couple bucks each from places like Summit or JC Whitney, but I haven't seen anything about bed spacers.
If my thinking is correct, all I will need are 4 body lift bushings, 8 bed lift spacers, and longer bolts. Does this sound right or am I missing something?
but what i did on my samurai was get a 2"x4" rectangle tubing and cut it in 2" sections on my samurai for my body lift
but im sure you want something a lil more "professional" looking ?
