changing torsion keys
i was using a 10lb hammer and an old 3/4 extension.
and i did use pb blaster. says so in first post. this aint my first rodeo. i've never ever had to pound that hard to try to remove a torsion key. im gonna soak it twice a day for another 2 days. if that dont help im gonna cut it off. oh and my crossmember cant be removed easily. i tried that too. theres a bolt on each end, no problem. but you cant lift it up to clear the mount because the exhaust is 3/4 inch above it on one side, the transfer case is about 1 inch above in middle and the brake abs thing is about 3/4 inch above on the other side.
I welded a washer and a grade 8 1/2" nut to the hole you put your extension through to beat on the bar. Then use a grade 8 bolt and impact to press it off. I did mine in the driveway with 120,000 so they were on there good. Smack the bar with a hammer as your putting tension on the bar. Now they I put my new ones on they slide right on and off pretty easily.
It worked well. Also made my own torsion detensioner with angle iron. May want to clamp the cross member to prevent it from spreading. I know it's kind of crappy idea but gotta do what ya gotta do.
13 Second Truck Club
I also had to unbolt mine. Ten years of salty winters had them stuck in pretty good. It wasn't as big of a pain as I thought it would be to pull the cross member out. I ended up having to get a buddy to hold a big punch with a pair of vise grips while I wailed on it with a 10 lbs sledge. Took probably 30 hits per side to pop them loose. Good luck.
maxspeed05V
11-11-2015 04:20 PM
iregret
09-10-2015 09:00 PM
atxlt
07-20-2015 11:06 PM
