Do you tow more than 5K? You need a new hitch.
yeah i know the hitch that we install at work (uhaul) is rated weight/weight dist. is 6000/8000 for 130 bucks and its beefy as the curt you put on. i got mine from factory and the most ive towed was 4000-5000lb big generator. was more worried about stopping than the hitch rating lol. looks good though.
Too bad for the wife I didnt get the two extra inches where it counts
I use to run a cheap russel hitch from walmart.. put alot of weight on that lil thing and it bends the frame.....
got one of the factory hitchs and its a ton better than the other one
maybe one day ill get around to getting a good hitch.
I like that flip hitch you got.
That's another reason I wanted this hitch because the forward mounting point(closest one to the axle) on this hitch is moved forward about 6". So the weight of the trailer is distributed over a larger area of the from. Your stories about your frame bending was a big reason I decided to get a better hitch now.
The B&W tow and stow is awesome, saves my shin from being annihilated and it looks cool with the Browning logo
10,000. There's not any options for adjustable height with a higher rating that I've seen. I'm sure the 10k is rated for it being at the lowest setting where the trailer would have more leverage on the ball mount. When towing heavy its always at the top so it puts less stress on the mount and hitch. Some guys on dieselplace have towed 20k with it before. I'd never do that just stating its a pretty damn stout chunk of steel.
Seems like good insurance for around $200 but I know so many guys who have put fairly heavy trailers on there stock hitch every day and never had an issue. It certainly won't hurt anything but I don't see it solving anything either.
Being class IV it has the larger receivers also doesn't it? Those cost significantly more and you can't always find them if you are in a pinch. It looks like your's has the standard class III receiver but I can't tell.
