Do you tow more than 5K? You need a new hitch.
#63
GFYS and STFU
When I bought my van the first thing I did was buy a Class V hitch for it from Curt but now I'm wondering if it's the extended one like the one you are talking about. They only have one kind right? This talk of frame bending's got be worried since I plan on towing 12,000-14,000lbs with the hitch eventually. My van is a 2500 which means the frame's a little thicker I believe.
Cody, come install my trailer brake on my van already!!
#66
Thats plenty.. ive hauled 16k with a reese hitch i got from walmart for $75.. it bent the frame where it was mounted but the stock GM hitch straightened it out when i tightened the bolts down
#67
The load distributing part is actually mounted to the trailer. also, brake controllers are simple. one wire to the "cold" side of the brake light switch under the dash, one to the trailer harness to turn the brakes on, and another to acessory power for the controller itself. It's hard to tell what harness they put on there for you, but Id recommend doing either a 6 pin round or 7 pin rv connector, then you can have brakes and aux power (aux is nice for trickle charging batteries in campers or for a trailer winch while youre towing. my little pop-up camper will also let me run the lights inside off the truck battery if its plugged in.)
heres a load distributing setup... Weight Distribution Kits | Reese SC Weight Distributing Hitch (1,200 lbs) | Drawtite | Reese | Tekonsha | Bulldog | Fulton
#70
There should be a pre wired plug under the bed. All you need is the adapter harness from the store that says "silverado this year to that year 7 pin plug adapter harness". Then under the driver side dash on the floorboard there is a little black box. Remove the center plastic nut from center of it and pop off the cover. Your brake controller harness will plug into that. My tahoe came with the needed harness. It if yours didnt have it in the glove box just go buy one. Should just be a gm brake controller adapter harness. Then match the applicable wire ends to your controller. Install fuse into the under hood fuse box. And boom all done. The brake controller harness to brake controller should be the only wires you have to splice. Everything else should be plug and play.
