Guys that drive on stuff other than paved roads club
#23
Hey... 800$ is still a damn good deal.
Could have been worse right?
arthursc2 (08-14-2020)
tjmath (08-14-2020)
#25
Hey @dantheman1540 whats your ride height at in the RCSB?
I really want it lower but with bigger tires. However I don't think I can go much lower without making the Tubular UCAs useless. Without any sway bars front or rear it's very "leany" which is why I would like to go lower. In the front it has so much down travel it will actually pull the CVs out when I jack it up. Need limit straps
#28
@bangbangskeetskeet Best thing I've found is the rear ground to fender is 38" even. That was after I added a Beltech drop shackle to the passenger side to lower it even with the driver side sag that was still there after swapping to Deavers. Front is probably close to 39-40 still as it was years ago after the first coilover setup.
What's your fender to ground measurement? Looks much taller!
https://www.performancetrucks.net/fo...ag-fix-552635/
