TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
How much lift for 36.5" tires?
Old 02-12-2007, 12:23 AM
tenshikurai's Avatar
Default How much lift for 36.5" tires?
Ok, I've already got a 3" body lift on the truck, and leveled it by cranking the T-bars. The 33x12.5 tires rubbed until I built my new front bumper, now I've got plenty of room. I'm wanting to do a 6" suspension lift and be able to fit 36.5's. However, I just picked up a 4" kit with a bunch of upgraded parts for cheap, I wanted more, but the price was too good to pass up. Will I still be able to clear the 36.5" tires? If I need to, I'll get new springs for the back, but the front is a little more problematic if I need an inch or two.
Old 02-12-2007, 01:30 AM
RandomHero's Avatar
usually you need about 9" of lift. So your 4" cranked to 6 and the 3" body lift should be fine. Especially if you have a ranch hand on there.
Old 02-12-2007, 07:34 AM
Senior Member
Country Boy's Avatar
9"s... How you get there is up to you.
Old 02-16-2007, 10:23 AM
MonsterZ28's Avatar
I thought 6" could fit 35's and 8" could fit 37's
Old 02-16-2007, 11:18 AM
Import Moderator
beastmode's Avatar
ive seen ppl wit 6" suspension and 3" body wit 35s... all depends on how much wheelin ya wanna do wit ground clearance
how wide are your wheels, i dont understand how 33s coulda rubbed, i ran 33x11.5 on 16x8 wheels wit just the tbars cranked and they didnt rub, i coulda ran 35s when i had my body lift on and the tbars cranked and the add-a-leaf??
Old 02-16-2007, 11:21 AM
Import Moderator
beastmode's Avatar
as far as the 8" clearin 37s i dunno but yes 6" does clear 35s if you trim that little valance part right on the corners
Old 02-16-2007, 03:16 PM
454Dually's Avatar
I've got 6" lift with 35's. doesn't rub. I dont see why you couldn't do 37 on an 8" lift..
38 with a 9" lift seems to look the best IMO
Old 02-16-2007, 06:34 PM
P.O.R.N.'s Avatar
11" and 36x15.5 you do not want to do 8" and 37's. GM's wheel well is to small, once you get to a certin point you have to get the tire all the way out of the wheel well or buy cut outs.
Old 02-16-2007, 09:34 PM
MonsterZ28's Avatar
are you still street legal ****?
Old 02-17-2007, 06:38 AM
Import Moderator
beastmode's Avatar
i dunno michigans laws but hed def be illegal in PA
Quick Reply: How much lift for 36.5" tires?
