Mine is 37 up front and 38 in rear with 265s. I know when I crank mine up to 38 up front everyone said my angles sucked. You are cranked 1.5 higher. Your angles must really be bad.
Do you have fender flair's on yours?? That will make a measuring difference..
it seems to ride alittle stiffer then stock height but nothing bad at all i havent put the body lift in yet im waiting on tires first. pretty sure im goin to run 305/55/20s
I'm at 38 in the front with 265s and I wouldn't go any higher. I've got about 1/2" between the bump stop and UCA.
In the first leveled pic, his LCAs look a lot steeper than mine.
