lowering question...
i have a 2008 ext cab texas edition silverado,and was wanting to lower it since it sits so high but i dont wanna lose the ride it has which is very smooth for a truck....will lowering it make me lose that quality ride or does it ride about the same depending on what lowering kit i use? sorry im new to the truck scene coming from the camaro ls1 scene...
Piss Pumps for Sale
Location: Moncton, New Brunswick, Canada, The True North Strong and Free!
1 Post
You can start off by lowering the rear by removing the 2 inch lift block between the springs and axle. That alone will make a huge differance in the stance. On the nbs you use to be able to just decrank your torsion bars to lower it, but on the 2008's Im assuming you would have to get lowering kit, as far as ride, taking the lift block out should if anything make it a little better giving you better handling, sorry I couldnt be more help, hopefully others will chime in here soon. Also welcome to Performance trucks
Zach
Zach
My suggestion is to just the level drop and see how you like it. If you're content and want a little more, instead of the 3/5 drop, try the 2/4 drop. I have the Belltech kit w/the nitrogen shocks as well and I'm digging the ride. Definitely a change. I'm also running with 20's. Along with the 2/4 drop kit consider the drive shaft alignment kit.. it will help reduce the amount of vibration from the drive shaft at higher ecelerations.
Lisa
Lisa
heres a couple pics of mine.
before shot
3/5 ground force drop kit
after shots
looks good too. mine is the dark cherry color, but otherwise i think theyre the same.
will lowering it void my warranty? thats whats holding me back from doing it now.
