Manuel Locking Hubs
Manuel Locking Hubs
I was told that the reason my fron diff. is not locking up is because I need to replace my hubs. I own a 1980 Chevy Blazer with a 350, what hubs would you all recommend. I see that the prices range from 50.00 to 300.00
you more than likely have an open diff . . . (spider gears)
the hubs are easy to strip. (getting airborne) Some are all plastic, or metal and plastic.
Once you've locked in the hubs, and it's in 4wd back up a few feet in reverse to "lock em in" . . . you'll feel it in the stearing wheel when they're locked
Manual hubs. Much better and you don't need to spend alot.
Mile Marker. Not for the most aggresive 4-wheeler but they will hold up.
www.ntwonline.com
www.ntwonline.com
I like the Mile Marker hubs. I had warn's on my '84 silverado and while they worked fine I think the Mile Markers are made better for the price. The metal insert that the cap screws into on the warns is aluminum and strips out to easily if you over tighten.
Cammed4ever
09-30-2015 03:38 PM
