is this ok??
is this ok??
so ive been busy enough and i got some money and bough these
ballistic jesters 17" wheels they look aowesome
the roblem is this. i have more space between the center axle and wheel than the stock wheel has
is this a problem?
do i need to buy different wheels?
tell me what to do
is this a problem?
tell me what to do
what he ^ said. The center bore of the wheel is wrong, but the bolt pattern is correct, you may try to locate some hubcentric rings, but I am not sure they make them to take up that much space. If you have no balance issues or wobbling in the steering wheel then I'd throw the center caps on and run them, if you do have issues then a wheel with the correct center bore is needed.
