Speed sensor Or Speedometer? (One is going out)
Hey guys
I need some info. My speedometer gets stuck sometimes and i not sure if its the speed sensor or the speedometer.
Where is the speed sensor located at on all wheel drive 2003 cadillac escalade? What are some symptoms when a speed sensor goes bad? what are the some symptoms when a speedometer goes bad?I want to try to fix the speed sensor first if its cheaper then sending my speedometer of to get the stepper motor fix.
Can someone give me some info?
You can have the dealership run a diag on the cluster. Takes less than 5 mins. Also, stepper motors are available on ebay... if you are comfortable working on the cluster yourself. If not, there are people available thru ebay that rebuild clusters for reasonable. Check it out. Almost for certain, it's the cluster. BIG GM problem
Pontiac Derek
09-19-2015 01:49 PM
creekrat
09-10-2015 12:59 AM
muncie21
09-07-2015 09:55 PM
bad, chevy, cummins, motor, out, replacement, sensor, speed, speedo, speedometer, stepper, symptoms, symtoms, trailblazer, wiki
