TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
suspension lift opinions
Old 11-13-2006, 08:39 PM
  #31
jakebdb56's Avatar
rough country = POS
IMO the SS irok radials are well worth the money.
here's a few pix of my old '97 3/4ton 6" procomp, 2" ford keys, 1/2 ton rear lifted springs, 37" irok radials on 16x10 discount tire wheels (woohoo). ne ways, here's a few pix.
Old 11-13-2006, 08:41 PM
  #32
jakebdb56's Avatar
also, the dual shock hoops did help a bit since the front end with that 454 was pretty damn heavy.
Old 11-16-2006, 03:06 PM
  #33
Twotonefreak's Avatar
Just curious Jakebd, but why is Rough Country junk?
It drops the diff. very close to 6", nice spindles and no torsion bars hanging down? I've had mine on for about 20K now and the front end is as tight as it was when I bought the truck. Also the ride is very nice and I have FORD keys in it also.
Old 11-16-2006, 03:08 PM
  #34
Originally Posted by magoo
The way I work, I will be happy to get it offroad once a month. I have another ride, for work. Plus right now I don't even know anyone to go offroading with or know where to go close to home. I was looking at the Rough Country 6" EX lift. Looks like it may change the axle shaft angle, but if I won't be offroading all the time, maybe it will last. And I can install it myself. (I don't have access to a welder or torch.)
Magoo, I have that same lift on my truck and love it. I've been off road a couple times, nothing serious and haven't had a single problem even after 20K in less than a year.
Old 11-16-2006, 08:11 PM
  #35
magoo's Avatar
Twotonefreak, What size tire and wheel combo to you have on your truck?
Old 12-20-2006, 01:57 PM
  #36
magoo's Avatar
Well, the wife's 52" HDTV put a kink in my lift. I think I will changing the keys and going with 305/70 16's on 16x8 classic II.
Old 12-20-2006, 09:52 PM
  #37
chewybravo's Avatar
IMO, you should probably go with a fabtech, then put some good ol' 35'' BFG All-Terrains.
Old 01-01-2007, 02:30 AM
  #38
magoo's Avatar
I am hearing that I will need a 6" lift plus a 3" bl to fit 35" tires. If I can fit 33" tires just by changing the keys, why can't i fit 35" tires with only a 6" lift
Old 01-01-2007, 02:49 AM
  #39
Need More N2O Mod
mwalls54's Avatar
thats not true. mabey if you went with a 15" wide tire you would have to have the body lift
Old 01-01-2007, 09:25 AM
  #40
Import Moderator
beastmode's Avatar
yea you can fit 35s wit 6", and you can fit 33s wit tbs cranked
Quick Reply: suspension lift opinions
