tire hight with a 3" lift
You may have to to a little bit of trimming but I think you'll be fine. My buddy and I lowered his Dmax about 2 inches onto 35's and we only had to trim a little bit off the inside of the fender.
not completely true...i had an 03 z-71 with a 3" body lift on 35x12.5's...only time it rubbed was at full turn while reversing, otherwise they fit fine. they would fit alot better with a 6" lift but you can fit them with a 3". Just dont go crazy with the width of the tire...i wouldnt go any more than a 12.5 width or they will probably rub worse. How exaclty are you achieving the 3" of lift though...body lift and/or torsion bars or suspension?
something else
I did a body lift with cranked T bars and I have 35's and no rubbing once so ever, the body lift is cheaper but you will have to live with seeing your frame every day... Some like it and some don't. It all boils down to personal preference. IMO a 3" lift is a waste of money you mine as well just spend a few hundred more and do a 6" suspension lift.
my truck is awd so i cant do a 6in lift because of the cv angles. i would have to spend alot more to drop the front diff and everything else so its not worth it. so im pretty much stuck with a 3in lift and34in tires if i do lift my truck.
