TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
Trans Temp Gauge recommendation....
Old 11-01-2019, 06:54 PM
Tuskyz28's Avatar
Default Trans Temp Gauge recommendation....
Im looking for a good solid proven accurate trans temp gauge for my 97 Chevy 3/4 ton truck. My truck is my tow pig with a 4L80E trannission and a factory trans cooler but i still want to watch how hot the tranmission is getting. I'll ne towing my camaro to LS fest yearly which is 5 hours each way. Anyway here is my questions...
Who have a good trans temp gauge? I dont mind spending a couple extra dollars for quality.
Is a deep trans pan really worth the money?
Thanks in advance.
Old 11-02-2019, 12:11 PM
stroker87's Avatar
i've always had good luck with autometer gauges, they have a lot of options from simple to digital cost will vary
i would install a larger external trans cooler inline before swapping pans, i have a 1/2 04 rcsb 80e swapped when i added a 30k cooler inline my temps dropped from 200'ish to around 160'ish around town
Old 11-02-2019, 01:27 PM
Tuskyz28's Avatar
Thats awesome
Old 11-03-2019, 10:54 AM
stroker87's Avatar
Originally Posted by Tuskyz28
Thats awesome
NP!
FYI i'm still using the cooler built in the radiator also, i have the return line from the radiator cooler feeding the external cooler then from the external back to the trans all the connection was done right at the radiator i cut the factor hard line flared it clamped it all good since
Old 11-03-2019, 11:44 AM
arthursc2's Avatar
Received 1,436 Likes on 1,063 Posts
Top line at the radiator is the return for a factory plumbed 4L60, fyi
I have a cooler plumbed in the same way as Smokeshow. I have hit 200 before, but mostly it camps around 150-160. It will hang around 130 with the TC locked on the highway tho. Minty fresh
turboal1
01-04-2018 01:07 PM
Wallywall
08-18-2009 06:53 PM
andrew383
02-20-2009 03:46 PM
Noah Burns
12-16-2008 01:15 AM
HAZE
06-28-2004 04:27 PM
Quick Reply: Trans Temp Gauge recommendation....
