TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
Upgraded transfer case?
Old 01-29-2009 | 01:04 PM
daddyzzs's Avatar
I have the push button auto 4 with 2wd, 4hi, 4lo just looking for something that is either 4wd or 2wd non of this slipping b.s. when I try to use it and a atlas is totally out of the question!
Old 01-29-2009 | 02:19 PM
Chevy Cowboy's Avatar
Piss Pumps for Sale
From: Moncton, New Brunswick, Canada, The True North Strong and Free!
np 241 swap, easy, enough said
Old 01-29-2009 | 09:41 PM
silveradol33's Avatar
Originally Posted by SynergyV8
I got a chuckle out of this. Apparently the Np241 on my Tahoe is not bolted to a 4L60E.
Do your research son before making an a$$ out of yourself. The NP241 comes in a 27 spline and 32 spline version on GM vehicles. What's the spline count on the 4L60/700R4? 27. Guess what else Mr. Know it all...it lines up too! The pattern is the same 6 bolt "Chevy" circular pattern the General always uses.
All I said is you will not take a 2500 or 3500 case out and use it on a 4l60. Thats it, MR know it all. U are the one that acts like you know everything and are a complete A$$ Hat. Yes Gm does offer many cases in 1500 and 2500 form, but you cant interchange the 2. Also I never said the 6 bolt pattern would not line up, just that the shafts would not.
I have used an NP241c in my solid axle swap, I know it can be done, and its no big deal. I was saying to go from a 80e to a 1/2 ton case you will need to convert the input on the case to match the output on the 80e, wich I am currently about to start for my swap, cause like already said the 1/2 ton case is more than capable of more power than most people will ever make.
Old 01-30-2009 | 12:17 PM
daddyzzs's Avatar
Thanks for all the help guys I just got my hands on a 6.0 l?4 so my swap is next then I guess I need to have the transfer looked at cause it only works when it wants to... ANYWHO thanks to everyone for the help and the
Old 02-10-2009 | 02:14 AM
black4x4's Avatar
Bigger, thicker and more material of all the internal parts, better oiling pump, stronger case. Used in high torque or off-road applications...or for anyone looking to never replace a transfer case again. An example would be comparing the 4L60 to the 4L80.
I will never let a computer decide for me when I should and should not be in 4wd. By paying careful attention to the terrain in front of me, I know ahead of time if I need the extra traction from the front tires. Leave the auto 4x4 stuff for the women.
But their both still half ton cases. yes you could get them in a 3/4 ton but still there a half ton case. and they will not last forever thats why my 241 needs to be gone through agian after one year of use.
Old 02-10-2009 | 12:22 PM
crawdad379's Avatar
Yeah I have a 3/4ton with a 241, dont know where the chain or half the case is I guess in the mud somewhere. I rebuilt a 1/2ton case and put my input shaft in for the time being, but prolly gonna build a doubler 203/205 case. 27/32 spline does seem general but some length differences in years and generations.
Old 04-06-2009 | 12:16 PM
fastlt1's Avatar
12 Second Club
So the 2500hd autotrac is no stronger then the 1500LD autotrac?
Old 09-17-2020 | 09:41 PM
Steve Engelson's Avatar
Registered User
Default NP246 to NP243 swap
will a NP243 fit a 99 Silverado 1500 with a NP246? If so what all is required to do the swap?
Alco
09-04-2015 05:08 PM
Three6GMC
08-28-2015 08:56 AM
04BlackGmc
07-16-2015 05:10 PM
Gadgetized
07-07-2015 05:40 PM
