what fits????
im currently considering getting a torson bar lift kit, helper springs and a 3 inch body lift. I have a few questions about what tires will fit afterward and how do trucks with body lift ride, i heard not so well, any input????
2nd fastest 5.3 ECSB
You should be able to get 285's or even 305's in there with a 3" lift.
you wont ever know you have a body lift until make a sharp turn. with two and a half inchs of torsion bar lift and a 3in body lift you can fit a 315 on a factory wheel with minor trimmin of the front wheel well
well i deffinitly plan on a suspension lift in the futrue im just going with what i have a budget for right now, so in the end ill have a 3 inch body 2 inch torson bar and a 9 inch susp. lift. But for right now all i can afford is that.
im buying 305/70/16s (33-12.5-16) going on 16x8 aftermarket wheels, will they fit with just keys or what? also im gonna put add-a-leafs in the back, should they fit? Is it ok to put the keys in and crank or not?
8 Second Club
they will probaly rub at full lock. Mine did with just the keys, before i did the body lift
Those are the exact tires im getting too, if not the baja claws the new baja MTZ. I dont make many 3 point turns so turning to full lock doesnt happen all that much. But your saying i should get the body lift too? And is that just cause of the front or all around?
