TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
What tires to get??
Old 07-20-2010, 09:49 AM
blackjack325's Avatar
thin wheel with wide tire is gonna give you that "donut" effect. I wouldnt risk it if I was you. Your tires are gonna wear out faster than they should.
Old 07-20-2010, 10:15 AM
00T/AWS6's Avatar
yeah i know what your saying but then there are no tires that can fit my rim in any decent size?? I can't afford another $500 for a decent set of used wheels. Got any idea's on a good lookin off road tire for me then to wrap around these stockers?? I sent nitto a message, so hopefully they can chime in for me haha.
Old 07-20-2010, 10:27 AM
id say 265 maybe 275 wide
Old 07-20-2010, 10:45 AM
00T/AWS6's Avatar
yeah that's what i was figuring too but didn't see the ones you suggested in that low of a size grrr.
Old 07-20-2010, 10:52 AM
traveling mod
andrew383's Avatar
Many have run the 285's and 265's on the stock 16's without issue...
If you dont want to go the 285 or route then you could run a 235/85/16.Its a hair taller than the 265 but narrower and would fit correctly.These are a great deal and its a good tire to run...
Old 07-20-2010, 11:42 AM
Mr. Obvious
nightrunner's Avatar
alot of people like the Toyo M/Ts. they are a mud tire but they are by far the best on asphalt and do really good off road also.
Old 07-21-2010, 07:23 AM
00T/AWS6's Avatar
Thanks for all the responses guys. Andrew383 you said many have run the 285's on the stock 16" rim?? I like that tread pattern on those ebay ones but I wanted something a little wider then 235's. I think 265 might be the best size as 285's might be a tad too wide.
Ugh decisions on wheels are such a PITA haha. Keep the information comming guys, i should hopefully be buying some this weekend if all goes well.
Old 07-24-2010, 12:03 AM
Tyglon's Avatar
I ran 285-75-16 BFG AT on my 2001 2500HD and they were fine without a torsion lift. When getting new tires I went with 295-75-16 Grabber AT2 and they rubbed. So I did a key lift. Then I bought new wider rims and they started to rub so I had to modify the bumper with spacers and cut back the lower valance. I wouldn't run Nitto Terra Grappler based on the reviews I've read on the HD trucks chewing them up in under 20k.
Old 07-26-2010, 10:29 AM
00T/AWS6's Avatar
Thanks for the info Tyglon. Did the 285/75/16's fit alright on your stock wheels?? They weren't too big for the little 16/6.5's?? That's all i'm realy worried about right now, i think they will fit in wheel well especially if i do torsion lift.
Old 07-26-2010, 08:46 PM
Tyglon's Avatar
Yeah, they ran well for me. I haven't had the truck since new, so I don't know how stock 245 rode. I could assume stiffer and the truck wouldn't be as much of a pooch. You will have to expect that. Other than that there was nice wear and no signs of the sidewalls going to hell. Planning a D or E? That could make a difference as well. Both of mine we D. Good luck.
Quick Reply: What tires to get??
