TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
wheel question...
Old 06-12-2008, 10:00 PM
traveling mod
andrew383's Avatar
Originally Posted by BLACK04VHO
I've got 18x9 with 4.75 backspacing roughly in their. here are some pics
can you get a pic from the front down the side? thanks
Old 06-12-2008, 10:16 PM
InchUp's Avatar
I'm not sure where you got the 2 inches from...but that's 3" plus some off the actual measurement. Jack your truck up, take a wheel off. Lay it flat so you can see the mounting hub. Lay a flat ruler or something across the lip of the rim and take a measuring tape and measure down from that ruler to the mounting flange on the back of the wheel. That's backspacing. It should still be 5.2".
Like this.
Old 06-12-2008, 10:42 PM
traveling mod
andrew383's Avatar
my bad i was goin off the front not the back
thing i dont get is if the bs on a 17x9 is 4.75" and the offset is -6mm the bs would be less than 4.5" rite??
Old 06-13-2008, 09:43 PM
Onetogofast's Avatar
Mine are 17X8's, I dont know the backspacing but my offset is -26mm and they set up in the fenders real well and close to stock, no rubbing, even when air born.........
andrewlong
11-09-2016 09:38 AM
sprayed99
09-21-2015 04:47 PM
George C....
09-11-2015 04:45 PM
andrewlong
09-08-2015 10:25 PM
the owl
09-04-2015 04:09 PM
Quick Reply: wheel question...
