TOWING & OFFROAD PERFORMANCE Towing |Suspension | Wheels | Tires | Drivetrain |where the pavement ends.
Widest wheels (with offset) and biggest tires on a stock suspension 03 Suburban?
Old 08-20-2009 | 10:29 AM
98Z28MASS's Avatar
Default Widest wheels (with offset) and biggest tires on a stock suspension 03 Suburban?
Hey everyone, just picked up a 2003 Suburban LS and I was wondering what the widest wheel I could run on stock suspension? I want to go with either a 16 or 17 inch wheel with a large tire (something along the lines of say a 295/65/16 or 17). Just throwing that tire size out there as an example. Also, how wide of a tire would I need to run a 285-295-305 sized tire and is it even possible on stock suspension? Sorry for all fo the questions and any information/recommendations/pictures of setups would be appreciated.
Thanks!
Adam
Old 11-23-2009 | 08:02 PM
sleeperlqx's Avatar
good questions.. searching and found this... still no answer...
Old 11-24-2009 | 07:48 AM
dhpro's Avatar
I run 305/50/20 and that seems to be the limit on width on stock suspension. I had some slight rubbing front and rear on the plastic well liner but nothing too serious. Front was a little more depending on what tire make u run (some have higher more square shoulders) and can tend to rub hard on sharp turns unless u do some cutting. I was looking into a 2/4 drop and not sure what that'll mean for tire width...I imagine it'll result in slightly narrower 295 to fit...R/
Old 12-30-2009 | 10:12 PM
jgwjr's Avatar
ive got 285/70/17 on my 04 2500. it has the torsion key turn up but thats it and i have stock 08 2500 rims.
Old 01-08-2010 | 11:30 PM
Tikiclub2's Avatar
I'm running 295/70R17 Cooper STT's and they fit great. Little bit of adjustment on your torsion bars and your golden.
Old 01-09-2010 | 11:30 AM
WJ MARK's Avatar
I had 305 50 20's on my truck. also ran them with the 2-4 drop. They are some wide suckers look cool as hell but add a ton of play to the steering. slightly rubbed with and without the drop but only when cranking the wheels all the way, not enough to bother me though.
Old 01-22-2010 | 05:04 AM
Midnight's Avatar
Mark do you have any pictures of that setup?
5.3Okasai
03-09-2022 02:07 PM
BoostedBowTie
01-03-2020 07:46 PM
Steve-O-08
04-19-2018 10:32 AM
Ketis
07-23-2015 01:37 PM
My72olds
07-10-2015 12:26 PM
