Silverado SS wheels on a TBSS
WANNABE GENIUS
Im curious if its at all possible to convert to the silverado bolt pattern on my TBSS. im a gig fan of the silvy wheels. Any one know?
If u sell your TBSS, what will ya drive?
I know what ya mean, u meant TBSS wheels. Even w/. adapters, before sellin off your wheels, I'd find out some backspacing specs on both. Otherwise, you could have the Cracker look, unless that's the idea.
Then you'll be stuck w/. SSS wheels that don't fit/ u don't want & you'll have to go get another set of TBSS wheels to replace the sold-off ones.
wannabess00, I know they have similar designs, other than SSS is 5 spoke, TBSS is 6 spoke. While back spacing might not be a big issue, I figured u knew they had different bolt patterns. I left that out only for that reason. I know there was a guy who wanted to run TBSS wheels on his Silvy, so I knew eventually a TBSS would wanna run SSS wheels.
I forgot who, but I think he was in contact w/. a wheel manf. & needed 20 sets before they'd do a direct fit TBSS wheel, no adapters needed. Correct bolt pattern & offset. Look around & ya might find it. G/L
WANNABE GENIUS
I know you are trying to go the other way with this but, these threads might open up a contact for you to get the proper info.... hope they help.
https://www.performancetrucks.net/fo...quot%3B+wheels
