engine/trans swap question
im feeling lazy and have a motor and trans that are still attached. has anyone tried to drop it in at the same time? if so, what are the odds that i can do it with all of the accessories still attached lol.
next question. will the OEM exhaust manifolds from an 05 escalade bolt up to the oem Y pipe from a 2000 silverado? reason for using newer manifolds is to get rid of EGR system. thanks for any help!
Tin Foil Hat Wearin' Fool
Yes you can install them together. Just have to jack the front of your truck up pretty good and angle it right on in. I don't think you could do it with the accessories on and the core support. I've done them together with my old stroker motor/80e and it was fine, even with having to dodge the front diff then having to throw the tcase on. Should be cake for yours.
