engine/trans swap question
Old 10-26-2011, 07:50 AM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Getting the core support lined back up can be a bitch if you go that route.
Old 10-26-2011, 07:58 AM
Bumpers's Avatar
I just took the top core support bar off of mine to put the engine and trans in together it was easy to slide right in and with my truck being as tall as it is can't really jack it up and get a cherry picker that will get the engine up that high lol
Needless to say I never wanna pull the core support and complete front end apart again
Old 10-26-2011, 09:34 AM
TXsilverado's Avatar
i jacked with it for 30 minutes and gave up. had the hood off, truck in the air, engine standing straight up...firewall wouldnt let it happen. sooooo i pulled the engine apart from the transmission while leaving the converter attached to the flex plate. im guna buy me an air hammer tonight to see if i can get that stripped converter bolt to break loose with some harsh persuasion.
Old 10-26-2011, 10:48 AM
Hunt&Fisherator
silver-mod-o's Avatar
gator grip that bish...
Ive had to wash a few bolt heads off factory stuck *** converter bolts with a torch
Old 10-26-2011, 10:52 AM
I have a gauge for that
Atomic's Avatar
last time I separated the trans from the converter still attached to the flexplate I broke the trans pump...because of a striped bolt as well...
Old 10-26-2011, 11:48 AM
hopefully i didnt break the pump lol. what went wrong that made it break?
Old 10-26-2011, 12:01 PM
1slow01Z71's Avatar
As the converter hub is coming out of the pump and the block finally pops out the dowel pins it can put too much pressure on the trans pump and crack it.
Old 10-26-2011, 12:10 PM
ffffuuuukkk. yeah mine put alot of pressure on it. would it be something i can see from the outside?
Old 10-26-2011, 12:20 PM
Resident Retard
BlackGMC's Avatar
I have used one of these before to install an engine/tranny combo in a few cars... Actually i have this sitting in a box in my garage...
Old 10-26-2011, 12:31 PM
1slow01Z71's Avatar
Look into the trans at the input shaft and see if you can see the two pump teeth sticking out. Use a screw driver and try and turn them. Hoepfully they dont twist. If they look good all you can do is drive it and hope it doesnt break. On my first trans swap I had a ahrd time seating the converter and ended up cracking the pump. 250 miles later it left me stranded on the side of the road.
Quick Reply: engine/trans swap question
