engine/trans swap question
Old 10-26-2011, 12:34 PM
  #21
dlt76028's Avatar
Broke
Old 10-26-2011, 12:41 PM
  #22
TXsilverado's Avatar
Originally Posted by dlt76028
Broke
my luck here lately
Old 10-26-2011, 12:49 PM
  #23
I have a gauge for that
Atomic's Avatar
Old 10-26-2011, 12:52 PM
  #24
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Its easy to pull the pump rotor out. There are a few bolts on the cover, then it just comes out.
Old 10-26-2011, 01:01 PM
  #25
so should i open it up and look, or just peek into it? are those notches at the 5:00 position the "teeth" that you're talking about?
Old 10-26-2011, 01:12 PM
  #26
1slow01Z71's Avatar
They can be at any position depending on where teh coverter stopped spinning at. There should be two of them in there and be directly across from each other. Thats what fits into the slots on the converter snout for the last "click" when youre seating a converter.
Old 10-26-2011, 01:17 PM
  #27
and i shouldnt be able to spin them right?
Old 10-26-2011, 02:18 PM
  #28
1slow01Z71's Avatar
No they can spin, they just need to be spinning together.
Old 10-26-2011, 07:50 PM
  #29
ok, airhammer > bolt. wish i left the trans attached and tried the air hammer first. anyways, the trans is dry on fluid, i looked in and everything looks fine and turns together with a screw driver like cody mentioned. slipped the converter in dry and noticed a squeeking noise that ive never heard before when turning a converter. any thoughts?
Old 10-26-2011, 08:33 PM
  #30
dlt76028's Avatar
refer to post #21. but seriously, maybe its just dry, a little lube never hurt anybody.
Quick Reply: engine/trans swap question
