Fire Pit Design
Fire Pit Design
I'm having a pool built right now and we are going to have a natural gas fire pit built as well. The builder does not supply the insert pan or the burner. After doing a little surfing I'm learning that this will be quiet pricy for the size that we want. I have the equipment and the skills to build it myself, but just not sure about the burner details (holes/jet size and spacing). Any help is appreciated.
I just added Propane pipe burners to my firebox on my smoker. I used one inch pipe with slits cut in it. Pointed the slits down so the fire would roll up from underneath. I used and wire welding gun tip to control the propane into the pipe. Works pretty good and with some trial and error I about have it right. Ill attach a pic that I used for reference when I started mine. But mind you this was set up for propane. I dont know how natural gas would burn in relation.
here check this out these are glass burner can use outside with gas logs or glass
Real Fyre Large Custom Burner System [OCBE-44] - $487.05 : Fire Magic Gas & Charcoal Grills, Real Fyre Gas Logs & Outdoor Kitchens
legerwn
56
11-15-2015 10:21 PM
Velocity1
09-22-2015 01:32 PM
