gallons into pounds........
So we have this calculator at work (aviation stuff) that converts gallons into pounds, for example: (this is for jet fuel)
1 gallon = 6.785 lbs
15 gallons = 101.775 lbs
20 gallons = 135.70 lbs
25 gallons = 169.625 lbs
maybe that'll help some of you guys when running at the track.
![Cheers!!](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_cheers.gif)
blownerator
maybe that'll help some of you guys when running at the track.![Cheers!!](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_cheers.gif)
Good info, I wonder if aviation fuel is heavier due to its content.
Great info man.
Now I know how much my truck will weight when I add jet fuel to its tank....![Tongue](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_tongue.gif)
But really that is usful info. Bet gasoline and jet fuel must weight about the same. Must be cool working with airplane too.
nick_4.8sierra
28
08-15-2005 12:07 AM
