Geoff @ Eps
#23
PT's Slowest Truck
I would think that a TSP cam would probably be "easier" for Comp to grind since it uses their own XER lobes, while Geoff has his own proprietary lobes that they have to grind, and as Corey mentioned, the setup for the machine may be a longer process. They might even want x amount of orders before they'll run some EPS cams off
#25
FormerVendor
The reply from our Comp rep when I asked if it could take weeks, for any reason, to make a custom grind...."No way. Most of y’alls ship the day after you order them."
#27
PT's Slowest Truck
Negative, if you're ever in Memphis, swing by Comp and they'll give you the tour so you can see the process. Their lobe masters are stored/kept right in the same filing room as the others and are setup on the same machines the same way. Comp doesn't have a minimum order amount or anything like that either.
#28
FormerVendor
I'm not going to sit here and bash Geoff....but I will say that I do hate to see my truck-brethren getting the wool pulled over their eyes and tricked into thinking 4-6 weeks is ok for a "custom" grind!
#29
EPS is only 1 person....its kinda hard to tune, build things, cam spec, order everything ya know? its a little hard for 1 man to keep up with everyone.
he's a good guy, and knows his stuff. he designed the Thunder Racing cams in Baton Rouge, so they guys loved them. now he owns EPS, and everyone is wanting his cams. i will wait 4-6 weeks for a bad *** cam simple as that.
my next cam will be bigger and be a lot better of a DD
#30
Tin Foil Hat Wearin' Fool
