Here we go...2007 Tundra unveiled
Old 02-09-2006, 06:51 PM
tmod's Avatar
Default Here we go...2007 Tundra unveiled
http://www.edmunds.com/insideline/do...cleId=109261#1
Originally Posted by Edmunds.com Inside Line
And he had plenty to discuss. Unlike the Nissan Titan that debuted with just two body styles and one drivetrain configuration, the 2007 Toyota Tundra will have three body styles (standard cab, double cab and crew cab), three bed sizes, three trim levels and three engines. The base 4.0-liter V6 and midlevel 4.7-liter V8 are carryover engines from current models and use a five-speed automatic transmission.
Top-of-the-line Tundras will get a new 5.7-liter all-aluminum V8 with continuously variable valve timing. No power numbers were mentioned, but with the help of a new six-speed automatic, the Tundra will have a maximum towing capacity of over 10,000 pounds. Toyota is also aiming for ULEV (ultralow emissions vehicle) certification for Tundras equipped with the 5.7-liter V8.
Toyota beefed up the rest of the truck by using stronger steel for the frame, a rear axle with a 10.5-inch ring gear, and four-piston brake calipers up front. And unlike the Tacoma, this Tundra has disc brakes in back as well. There are adjustable tie-down points in the bed, and it rides in on a set of 20-inch wheels that will be available from the factory when it goes on sale in January of 2007.
More info and images are also available at Toyota's website.
Old 02-09-2006, 07:20 PM
SSlow 4.8's Avatar
not a bad looking truck. has a dodge look to it.
a tundra with a 5.7 v8 would be nice... wonder about the power ratings. They also mentioned stronger steel frame.. wonder how heavy it'll be?
Old 02-09-2006, 07:43 PM
KySilverado's Avatar
I've got a lot of hours in several of the parts in that truck.
Old 02-09-2006, 09:46 PM
BlackLM7's Avatar
Not bad I guess. Front looks alright but I don't like the side profile. I think Toyota has a winner here.
Old 02-09-2006, 10:21 PM
Looks good and it will give the nissan titan a run for its money.
Old 02-09-2006, 11:10 PM
blk03's Avatar
man, they keep getting worse looking.
Old 02-09-2006, 11:52 PM
Keith's Avatar
Old 02-09-2006, 11:53 PM
duwem's Avatar
my first thought
Old 02-10-2006, 06:10 AM
TG02Z71's Avatar
That big shell around the grille looks like ***.
Not for me.
Old 02-10-2006, 10:42 AM
tmod's Avatar
Default Another pic...
The number of initial powertrain choices and body configurations is great. I guess this means we can expect a new SUV and/or a redesigned Sequoia soon...that should be interesting.
Quick Reply: Here we go...2007 Tundra unveiled
