Hp Tuners was just delivered
Old 09-06-2012, 10:08 AM
walledition's Avatar
UPDATE: had time to connect hp tuners to the truck, didnt edit a thing but saved the current tune file and made a run from 0-132 miles just on the highway (let me know what you think or if u see anything wrong on my tune)
File Type: hpl
File Type: hpt
Old 09-08-2012, 08:45 PM
ok today i started adjusting my mph, i knew it was way off and i sow my tuner forgot to put the right tire height in, it was at 31 and i changed it to 28.2 and i checked with my gps and now cluster shows my real speed (im happy about that) BUT ive been reading around and i learned that shiftpoints are not just based on rpm but also on speed, now that i adjusted my mph wont the shift points change? i mean truck used to mark a lot faster then i was really going, now i need more rpm to get to that speed, so again, wount my shiftpoints mess up this way?
Old 09-08-2012, 09:23 PM
black04's Avatar
It uses rpm when you are WOT and speed when you are cruising. You just gotta play around with it and see what feels best.
Old 09-08-2012, 09:32 PM
i just compared the files and it adjust all the speeds automatic, it shows lower speed now at shifting so i guess im good
shift points are sat at 6650 and it shift a little different every time but around 6512 to 6613
i guess its normal seeing a little shift differences in every log and every gear is always different
Old 09-13-2012, 08:46 PM
can someone tell me what else i need to install my car style injectors then pigtails and tune?
02AWDAWSDenali
10-01-2015 05:08 PM
Chevy305
09-28-2015 09:21 PM
Raiderjim
09-28-2015 10:37 AM
bisqikss
09-27-2015 09:40 PM
sTNT971
09-26-2015 04:22 PM
Quick Reply: Hp Tuners was just delivered
