I have figured out the cure to blown head gaskets
Old 08-10-2012 | 04:40 PM
Mangled03gmc's Avatar
Baltimore Whore
Talking I have figured out the cure to blown head gaskets
After, many many nights, cold beers, I have figured it out. All you have to do is weld the head to the block. You would either need to switch the block to aluminum or switch the heads to steel. Easy as that
Old 08-10-2012 | 04:41 PM
nonnieselman's Avatar
Guess you didnt know you could weld Alum to Cast???
Old 08-10-2012 | 04:44 PM
Baltimore Whore
Yes but alot of others may not be aware of this. Plus it could involve extra costs, Jeeze
Old 08-10-2012 | 04:46 PM
BlackGMC's Avatar
Resident Retard
Screw welding. This is why the Car Nerds invented JB Weld. Geeez your such a newb.
TX Tahoe Z71's Avatar
Rotary engine FTW
Old 08-10-2012 | 04:52 PM
Devcon or JB Weld would work just fine..
Old 08-10-2012 | 04:56 PM
1dirtybird's Avatar
I was thinking Panel Bond... that **** is nasty
Old 08-10-2012 | 04:58 PM
Baltimore Whore
I think you could also use HVAC tape. It is pretty good chit.
Old 08-10-2012 | 05:00 PM
TXsilverado's Avatar
JB weld with studs would be a pretty stout combo. good luck on the rebuild.
Old 08-10-2012 | 05:03 PM
tiffo60's Avatar
it would work but you would also have to put access panels on the side of the block if you ever needed to inspect the valves
