Need to rent a 20'+ trailer
I cant find anywhere to rent a cargo trailer bigger than the 6x12 u-haul has. I see no reason to rent a moving truck when i have plenty of *** to pull a trailer with everything i own, but i cant find a trailer big enough to rent online. Any affordable options?
How far are you needing to move? I know, at least where I'm at, a few places will rent you cargo trailers for local moves. Might just have to check around, or go with U-Haul's larger trucks. Regardless if you've got a rig to pull with, if you can't find anything, you might have to go with that. I don't know what the going rate is on a larger U-Haul nowadays, but it can't be too much.
Tigger Welder
10-01-2015 08:41 AM
