need some truck advise...
ADVICE...lol whoops...
as some of you may have remember, I started to build my 2000 silvy back in march with a turbo'd 4.8 along with a t56 swap...well after having problems with the stock crank on the 4.8 being too long and not working I had decided to bring my 6.0 block to the machine shop to be put together...
seeing I bought a new truck for a daily driver I told the machine shop to take their time with it seeing I was in no rush...the block is punched out and the 317 heads are all set to go, just needs the rotating assy...here is where the problem comes in...
if I go ahead and put in the 408 I still have to buy a new double disk clutch which is around $1200 bucks or so, beef up the trans for around $1600ish and of course the purchase of the engine which is at least $3k...
I already have the following
-ls7 clutch
-stock m12 GTO T56
-kbracing turbo kit
-gt4202r turbocharger
-60lb injectors
I also have lots of miscellaneous items that relates to my turbo build such as oil lines and fittings, gauges, etc...but Ive started to lose interest in the truck seeing I havnt driven it in so long and Im sick of spending money on it...
Ive now toyed with the idea of buying a stock crank from an auto 4.8 or any gen 3 and just throw it into my 4.8 and put the 317s on it...reason why Im thinking of this is I just have to a fraction of the money to get the truck going and I can enjoy it until I save to rest of the money for the rest of the build...
soo my question to you all is, is this a dumb idea? Im just nervous that if Im going to run out of $ and patience and just ditch the whole project...I would imagine that with me putting the 4.8 together it would maybe be a total $1k to get the truck going vs. at the least $6k
let me know your opinions...
-ls7 clutch
-stock m12 GTO T56
-kbracing turbo kit
-60lb injectors
I agree...I should have mentioned that as well...you can find a complete running 5.3L for dirt cheap...so it might be even cheaper to buy a compete engine, put an ls6 cam and springs in it and just drop it in...
ok well I think that Im gonna pick up that 5.3 this evening as long as it look alright...now a quick question for all you boosted guys...
I have a comp 216/220 on a 114lsa sitting on the shelf...I was prolly just gonna run this cam, anyone see any reason why it wouldnt work well? I also think i have a set of ls6 yellow springs somewhere but I need to find them 1st...
cant wait to start putting the truck together and drive it again lol should be interesting with that big turbo on it...oh well its what I got
well ended up getting the 5.3 last night...the IAC was busted on the throttle body and the MAP sensor was loose too so I ended up getting it for $350 and he gave me a nice little stand too...
now Im just gonna put that cam in it, replace the intake mani and throttle body with the one from my 4.8, but the 60# injectors in and let'er rip...
Suburban2500
07-19-2015 04:50 PM
Mossyoakglock
07-17-2015 08:30 AM
Nimoryan
07-05-2015 03:50 PM
