The neverending OVERHEATING issue...please help!
Old 10-14-2005, 09:04 AM
  #41
Sexy Party Mod
FarmerBeau's Avatar
My bet is on the fan clutch. Can you hear it kick on?
Old 10-14-2005, 09:49 AM
  #42
ChillOutWayne's Avatar
Well im hoping either of you are right, im dropping the radiator off in 30 minutes for the day, and picking up a fan clutch as well. Both will be installed tonight and we will see what happens.
Ill keep ya posted.
Dan
Old 10-15-2005, 09:10 AM
  #43
20 miles on the highway last night, never went above operating temp.
Radiator was 45% plugged, threw a brand new one in and bled the cooling system, drove and couldnt be better.
God i am so relieved, thanks so much for all the help guys. Now i just gotta figure out why the gauge jumps slightly and why the rear main throws a few drips out only after vehicle is shut off and why the air bag light flashes.
But ill worry about that another day, for now, time to get smashed.
thanks again to everyone for the help.
Dan
Old 10-15-2005, 03:10 PM
  #44
Just took it for an hour ride with the scanner on. Temp never hit 200, in fact temps on the highway stayed right about 190-194, and on the street it would peak at 195 then drop to about 188 and continue that cycle. God i feel like that damn van just fell off my shoulders. Thanks for all the help here guys, i appreciate it.
Dan
Old 10-15-2005, 03:46 PM
  #45
SSlow 4.8's Avatar
glad to hear you figured it out.. i bet thts a relief!
Old 10-15-2005, 04:09 PM
  #46
You have no idea, i can actually sit and watch the home team (White Sox) play with a beer in my hand, instead of laying under the van full of coolant listening on the radio.
Dan
Old 10-15-2005, 05:37 PM
  #47
Sexy Party Mod
FarmerBeau's Avatar
Glad everything panned out. Drink a brew for us!
Old 10-16-2005, 12:37 AM
  #48
Tribe Shaman
PappyDan's Avatar
i want a beer
Old 10-17-2005, 09:49 AM
  #49
Neil 6.0's Avatar
Location: as far away from Koonerville as humanly possible
Old 10-17-2005, 06:06 PM
  #50
PT's Slowest Truck
budhayes3's Avatar
Originally Posted by PappyDan
you can flush it all you want, if the cores in the radiator is clogged from minerals in the water flushing it will not help.
after the radiator shop is done, you should have full cooling ability back
Most common thing I've seen for overheating on the highway is insufficient coolant flow through the radiator, or air flow across the radiator. Running water through it isn't enough, it must be rodded and boiled, or replaced. Another item I've come across, though not very common, is impellers on the water pump rotting away. This will also give more problems on the highway in my experience. But I'll almost bet that the radiator is the problem.
Quick Reply: The neverending OVERHEATING issue...please help!
