The neverending OVERHEATING issue...please help!
#51
Most common thing I've seen for overheating on the highway is insufficient coolant flow through the radiator, or air flow across the radiator. Running water through it isn't enough, it must be rodded and boiled, or replaced. Another item I've come across, though not very common, is impellers on the water pump rotting away. This will also give more problems on the highway in my experience. But I'll almost bet that the radiator is the problem.
The water pump is brand new, so i eliminated that pretty quick, my only other concern was that i was pulling in air still somewhere, ie cracked head or something along those lines.
Dan
Tigger Welder
10-01-2015 08:41 AM
Shotguntommy
09-15-2015 05:24 AM
85, car, cylinder, e150, expressway, head, kz1000, occasionally, overheating, overheats, pattern, temp, van
