New Rider... Have Questions
Hunt&Fisherator
Well sadly the test didnt go so well haha
I buckled under the pressure and stalled on the hill.
EVERYTHING else was a pass. I hit the steepest hill my city has to offer and practiced for about 2 hours today; gonna go again tonight and I booked another road test for tomorrow evening
What method do you guys use on hills?
I hold back brake and let out clutch till friction point then accelerate and let off brake and clutch
That would take 3 feet on my bike. No front brake. And a foot clutch... But. On a hill I will leave the bike in gear and slip the clutch to hold myself in one spot until I take off. Yeah, it's not real great on the clutch plates but I don't put a ton of miles on my bike and I can swap plates and readjust the clutch in about 20min with a couple hand tools. On the side of the road if need be. One thing about my open clutch setup is it gets rid of heat very well. I've forgotten how to ride something with a front brake honestly. Id probably lay one down if I had it.
On your setup. Id recommend leaving the bike in gear, clutching and braking to the stop, feet down and hold yourself with the front brake. When you're ready to go, ease off the clutch until you feel it start to grab, then you can ease on the throttle and off the front brake. Hydraulic brakes make this way easier than mechanical. You can operate the brake with one finger and leave the rest of your hand for throttle. Takes a little practice but that's how Id go about it. Leaves both feet down which is always preferable.
Main thing is don't give up. Keep practicing, you'll get it.
Riding the clutch on bikes isn't a big deal. They are wet clutches after all. My last bike had over 73,000 miles and hard miles to boot of stunting and not one clutch issue. OP it just takes practice. If your haven't already I highly recommend a MSF course. My wife took one last year and in the long run made her a more skilled rider
Hunt&Fisherator
This is not true of all clutches. Excessive slipping of the clutch will cause premature wear, or at least it has on every one I've ever laid eyes on. You just have to be mindful of it and not overheat the clutch and potentially warp and stick clutch plates. And also, not ALL of them are wet. Matter of fact, of the 5 bikes currently sitting in the shop, 3 of them have dry clutch setups.
1 Post
I passed the exam today! So that's definitely a step in the right direction.
What do your guys' road tests cost down there? Mine was $135 and then another $30 to get a new lisence
TAPyvehc93
09-12-2015 08:19 PM
