View Poll Results: Should I attempt to rebuild 5.3 myself?
Yes, its not too hard to do
100.00%
No, way to difficult
0%
Voters: 11. You may not vote on this poll
Shoud I attempt a 5.3 rebuild myself?
Old 06-11-2009, 09:13 PM
13 Second Truck Club
A Low Dime's Avatar
Default Should I attempt a 5.3 rebuild myself?
Im thinking about freshening up the 5.3 I bought recently with new bearings(main, rod, cam). Im going to send the block out to have vatted, honed and have cam bearings pressed in.
I have knowledge of internal engine and will also be researching procedures of installing the bearings. As long as the crank is fine(which I will have polished) buying stock size bearings should be fine? I will also be ordering some plastigauge for the install.
Should I attempt to assemble the bottom end myself?
I want your opinions and definitely want your knowledge of bottom end assembly. Specifically torquing bolts and what not.
Old 06-11-2009, 09:16 PM
Tribe Shaman
PappyDan's Avatar
well sure, go for it if you have the right tools.
but since your going that far just go a little futher and make it a 5.7 with some
LS1 pistons.
Old 06-11-2009, 09:17 PM
JoeGibbSilverado's Avatar
go for it! thats the only way to learn, by a book for it, and go to town, good luck
Old 06-11-2009, 09:19 PM
A Low Dime's Avatar
LS1 pistons.
That was definitely in my mind, BUT the machining would add about $400 to my bill. One of the reasons I even decided to start the swap was because I picked up the motor cheap.
BUT nothing is set in stone yet. If I come across LS1 rotating assembly in the next few weeks, I may make an Iron 5.7
Any particular tools you had in mind that I would need?
Old 06-11-2009, 09:21 PM
rubber mallet, lol, plenty of sockets, good ratchets, torque qrench...... just to name a few, u want a clean workplace, dirt and dust to a minimum, especially when working with rotating assemblies, and most of all, read up, and take your time
Old 06-11-2009, 09:22 PM
A Low Dime's Avatar
Oh, definitely got that.
Old 06-11-2009, 09:25 PM
also, standard bearings would be fine if all u are doing is polishing, and not having it turned, the machine shop will let you know
Old 06-11-2009, 09:26 PM
GMCtrk's Avatar
For what you have in it, I wouldn't touch it. A gain of .4 liters isn't worth the time, especially in that light truck. From what I've seen a proper engine rebuilding kit (the brand name escapes me now) is around $500. Add on top of that the machining costs and I really don't see it being worth it. I've seen low mile 5.3s going on ebay for cheaper than that.
Old 06-11-2009, 09:29 PM
A Low Dime's Avatar
I talked with TSP earlier and for all three sets of bearings (main, rod, cam) its $170 shipped for all of them.
Old 06-11-2009, 09:37 PM
something else
ChevyTruck's Avatar
I say do it, make it a learning curve for your self. I would make it a 5.7 also just to add that much more pride into it.
Quick Reply: Shoud I attempt a 5.3 rebuild myself?
