View Poll Results: Should I attempt to rebuild 5.3 myself?
Yes, its not too hard to do
100.00%
No, way to difficult
0%
Voters: 11. You may not vote on this poll
Shoud I attempt a 5.3 rebuild myself?
Old 06-11-2009, 09:40 PM
nonnieselman's Avatar
Build it up and learn ya something.. I wish i had the time to do all that..
Old 06-11-2009, 10:05 PM
supersub's Avatar
get arp bolts for the rods,mains and heads. other than that, go for it.
Old 06-11-2009, 10:24 PM
DBYRD's Avatar
DO IT! ull learn a lot!
LsxCody's Avatar
Do it. Shouldn't be too hard
Old 06-11-2009, 10:25 PM
13 Second Truck Club
A Low Dime's Avatar
That is the plan. I think Im going to go with new GM bolts for the heads. Once I send the heads to WCCH to be worked once the swap is done, Ill replace the head bolts with ARP. $29> $150 May do it now tho too.
Old 06-11-2009, 10:42 PM
A Low Dime's Avatar
Are pretty much all the gaskets re-usable, besides head gaskets?
Old 06-11-2009, 10:43 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
If you are going to the trouble of tearing it apart get it bored. Boring the block should be no more than 200 bucks, the hone is the same whether you bore it or just clean it up cost wise.
Id look into forged rods and pistons for an iron 5.7, you would have an awesome motor then, Richard@WCCH can get them for you for a decent price.
Ive got all the tools to build the motor Id consider letting you borrow, after Im done building the LQ4 Im working on at the moment. Its not hard, just take your time. Me personally I dont like plastiqauge, a dial bore gauge and calipers is better IMO. If you have any questions, just post up, Ive got a list of all the stock bearing tolerances, and can tell you how to measure them all, along with ring gap. Ring gap will be decided by the ring manufacturer for your intended use though if you go with aftermarket.
Old 06-11-2009, 10:45 PM
1slow01Z71's Avatar
All gaskets except heads and IMO replace the rear cover crank seal, that one can be finicky to get aligned right and would best to start off with a fresh one, the front timing chain cover seal, just dont tighten up the front cover until the crank pull is seated then tighten down the cover. This will keep the crank pulley from rubbing on one part of the seal and burning it up.
Old 06-11-2009, 10:51 PM
A Low Dime's Avatar
Ill definitely be interested in all that information, lol.
I have been researching prices for two days. Im not 100% on staying 5.3 or going 5.7 yet. All the pricing I have done applies either way, just add on a bit here and there.
Old 06-11-2009, 11:50 PM
A Low Dime's Avatar
I just pulled the main cap off, bearing looks good.It only has on spot where it has a very light dull spot.
Quick Reply: Shoud I attempt a 5.3 rebuild myself?
