******1990 C1500 643hp @ 13psi******
Up for sale is my 90 c1500 that has been gone thru completly. Top to bottom. It was built last year and has about 1000 miles since it was finished. Looking to build a diffrent project and this one has to go. I will sell complete running or with out the Holley Dominator efi system. It made 643 hp on 13psi boost. Had gone a best of 11.1 on boost only. Taking it out next week to run a full nitrous pass. Should be 10.xx running truck. Best 60ft has been 1.61 looking to get $14500 compete or $11500 with out the holley set up. Keep in mind the complete holley sytem I have cost over $5500. If you're still intrested keep on reading. Lol I will post pics tonight. I have title in hand.
Exterior
New paint Corvette lemans blue with 4 coats of clear
New front and rear glass
New door hanldes
Bed liner
Color matched front grill
New head lights, turn signals and tail lights
Chassis
VAS 4/6 drop
VAS c notch with inner cnotch plate for reinforcement
VAS Tracbars
VAS leaf spring slider kit
Mcgaughys 2 inch springs
Mcgaughys 2 inch spindles
Rear end
chevy 10 bolt
Detroit trutrac
moser axles
narrowed 1" per side
6 piston wilwood disc brakes
Engine
4.8l stock rotating assembly
New file fit rings. Gapped for turbo app
Arp head studs
ls9 head gadkets
Stock 4.8 boost cam
.600 lift valve springs (cant remember the brand)
Trans
2007 4l80e
circle d 3200 stall
Hd shift kit
Turbo kit
KB Racing compound kit
borg warner s480
magnum 60mm
Hot pipes
4.5" front mount intercooler
full 4" exhaust with magnaglow muffler. Extremly quiet!
Fuel system
99+ fuel tank
twin walbro 450 fuel pumps
120 injectors
aeromotive regulator
Braided lines
-8 feed
-6 return
stock fuel rails with welded -8 fitting for crossover
Holley efi progressive Nitrous kit
NOS nitrous plate
150 shot nitrous set up
ECU
full race computer.
Touch screen Pannel with gauges
Wheels
15x8 steel wheels uo front on Mickey tompson tires
15x8 bead lock wheels woth 28 MT radials
15x10 steel wheels with new 28 MT radials
Exterior
New door hanldes
Bed liner
Chassis
VAS 4/6 drop
VAS Tracbars
Rear end
chevy 10 bolt
Detroit trutrac
moser axles
Engine
Arp head studs
ls9 head gadkets
Stock 4.8 boost cam
Trans
2007 4l80e
circle d 3200 stall
Hd shift kit
Turbo kit
borg warner s480
magnum 60mm
Hot pipes
Fuel system
99+ fuel tank
120 injectors
Braided lines
-8 feed
-6 return
NOS nitrous plate
ECU
full race computer.
Wheels
maxspeed05V
11-11-2015 04:20 PM
LSX-81-SIERRA
08-31-2015 05:52 PM
