03 rcsb vitory red lq9
located in Hammond Louisiana.
2003 silverado regular cab short bed, red. its the LS model with power everything and steering wheel contorls.
installed a center console with bucket seats, driver seat is power
installed blue leds in all the dash and steering wheel controls, including the radio and a/c panel.
also has air/fuel and boost guages on the pilar hooked up too
has a 2 inch drop shackles in the rear
now motor is a 2005 lq9 with same 4l65e tranmission rear end is a 10 bolt 3.73 with g80. the tune was done by allen at futrels in walker. with the charger it was 386 with 4 lbs. as it sits now its 321 at the wheels with the 275/55/20s
i have the dyno sheets to prove it.
i bought the motor with about 60k miles on it and did the swap. i ran a powerdyne charger on it for about 3000 miles then i destroyed the power dyne and have not installed anything else. the motor has the 42lb/hr injectors in it now. Aslo has shorty stainless headers 1 7/8 primarys. no cats and a single 40 series flow master. single pipe exiting after the rear tire in factory place. Has a pretty good sound but not really loud.
transmission was rebuilt by a local transmission shop here in hammond. about 12000 miles ago
just installed rear brakes and calipers, front pads are still in the box havent had a chance to change them yet.
motor has about 80 k on it now. doesnt smoke or leak and still feels pretty damn strong.
Has tinted headlights and turn signals with HIDs in low beams
i have 20s on it now but also have the factory rims and tires to put back on it.
bad things.
front shocks i think are about shot but i do have another set that are still good.
there are a pretty good amount of scratches and small dents on the truck and clear coat is peeling in spots.
rear axle twist alot when you give it alot of throttle from a stop, but i guess its kinda expected.
needs an alignment but im planning on doing that next week.
well if your interested give me a call on my cell 985-222-6021, ill send you pictures through text. i need to get $9k for it with out the rims, i have other plans for them.
I am in desperate need of a 3/4 ton and dont have the time to play with it anymore. Let me know what you think.
thanks, John
bad things.
thanks, John
Superman09
09-25-2015 05:55 AM
