07 turbo 6.2/80E silverado FS
Old 10-08-2010 | 04:35 PM
Daryn's Avatar
Formerly darynC-10/23/10
Default 07 turbo 6.2/80E silverado FS
on the new built motor dyno 550/550 on 10 psi with a safe tune
truck is an 07 ,70K on body (work truck)
motor is an 08 L92 from a denali
the motor.....
-diamond forged turbo pistons
-callies compstar rods
-total seal rings
-mild turbo cam
-dual springs
-hardened pushrods
-arp headstuds
turbo kit was build by myself . 2.5" cross over into a 2.5" log 3.5" DP,
duramax stock muffler
-31x12x3 intercooler with aluminum cold pipes. t bolt clamps on everything!
-precision pt74gts ,fresh rebuild
-tial MVR44 WG vent to atmosphere
-tial 50mm BOV powdercoated low gloss lack
-FIC semiens 60#(43.5psi) injectors, they are around #70 with 60psi fuel pressure
-billet fuel rails with aeromotive bypass regulator
-bosch"044" intank
-TCI 4l80e flywheel
-ultralite boost gauge
-strange s5205 coil over shocks relocated behind the rear end
-rear end has 3.42 gears with a eaton posi
-flip kit with spring perches welded to the axle
-mcgauhy's spindles and drop springs in the front.
4l80e from a 06 2500 it has
HD2 shift kit
30K cooler,
modified crossmember ( tubular)
built 3" steel driveshaft with Strange forged slip yoke and 1350 joints
sittin on chevy 20's front tires are 60% rears are 75%
truck has no evap or charcoal canister anymore. dont need that sh*t anyway.
would trade for a stock crew cab 06+
price drop!...im askin 17k as is or 12k with a stock motor(5.3) and no turbo kit
my cell is (225)405-4124 ,serious inquiries only. dont call just to chat.
Old 10-08-2010 | 06:58 PM
D_reks{5.3}'s Avatar
Awesome truck man, sad to see it go. Good luck with sale.
Side note: Nothing against you, But howcome everytime someone does a bad *** build and gets it finished they turn around and sell it after its done. Seems like you do all that hard work for someone else to enjoy IMO. I understand things come up and sometimes stuff has to go. But Alot of people do awesome builds and just turn around and sell them for someone else to tare up. I wouldnt spend all the time and money if I was planning on getting rid of it when its done..
Old 10-08-2010 | 07:26 PM
CrusinSilverado's Avatar
Registered User
I will agree awesome build, as mentioned to bad your selling. Good luck with a sale.
Old 10-08-2010 | 07:43 PM
kbracing96's Avatar
Some people enjoy the build process more then the end product. Guess that's why I've had 5 different turbo setups and to blowers on my truck!
Old 10-08-2010 | 07:52 PM
I figured that was the reason, why not keep it and build the next thing? haha. And switching setups is different, atleast you still have the vehicle.
back to the for sale ad. BUMP
Old 10-08-2010 | 08:59 PM
Daryn's Avatar
its not that i WANT or NEED to sell it. im just throwing it out there. i cant take this truck with me when i die thats why i went all out with this build , and did everything correct(within budget), no cutting corners, no half assing it.
Old 10-12-2010 | 12:31 AM
Daryn's Avatar
hoping to knock a low 12 .......... towing a trailer
Old 10-12-2010 | 07:51 PM
Slay0r's Avatar
dam...sick build
and HP/tq numbers? or track numbers?
would love to know what this thing can do
Old 10-12-2010 | 08:55 PM
smokeshow's Avatar
Mod with training wheels
Hell of a truck. If I was in the market it would be mine
Old 10-14-2010 | 02:15 AM
Daryn's Avatar
times and number will be up soon!
