1992 Somoma roller
1992 Somoma roller
The truck is white and has power windows and power locks with late model s10 seats with new carpet. The dash is cover in gray vinyl. The body is pretty straight except for the hood that has some small dents .It has new ball joints and tie rods ends with a fresh alignment and new brakes, The holes in the fire wall have been welded shut, smoothed and painted. It also has all new electric Autometer guages.
1992 Regular cab s10,Hedman 1 3/4 inch heads stepped to 1 7/8 inch fender exit headers, 3 inch x pipe with Flowmaster mufflers. Fuel system consists of a 10 gallon aluminum fuel cell with Aeromotive fuel pump and regulator, stainless steel braided 10AN feed and a 8AN return fuel lines, a 10 and a 100 micron fuel filters. It has 6AL ignition box, Painless wiring fuse box. The battery is in the bed and has a flaming river remote cut off switch, a sealed battery box with a new battery.
The cooling system has a new s10 specific aluminum radiator with twin electric fans, and an electric water pump.
It has a 8.8 explorer rear end with 3.73 gears with slapper bars. The transmission is a rebuilt turbo 350 with a Jeg's 9+ 3200 rpm stall convertor.
The truck has QA1 adjustable shocks on the front and rear.
$4000
The truck can come with a typhoon turbo V6 for if interested
$4000
your right a roler does not come with the motor,I sold the motor that was in the truck. I just thought I would just throw the other motor out there if someone was interested.
jscherbs
03-24-2017 07:20 PM
