2000 tahoe limited 88k miles roller 3k
Well I just have too many damn cars/trucks and I don't ever use it.
2000 chevy tahoe limited (4dr 2wd police package) 88k miles on the truck, clear clean title, original owner.
has a 14 bolt 9.5 semi floater with an eaton posi (from 454 SS) with redone spring perches and 4 deg of pinion angle to plant the rear without traction bars
custom true dual 3 inch rear side exit exhaust
hotchkis swaybars
braided brake lines and larger calipers
hydroboost brakes
1350 driveshaft setup for a 4L80, trans mount for 4L80
poly motor and trans mounts
steel cowl hood, billet grills, SS tags from a early 2000's monte ss
I yanked the radio, amps and speakers out of it, all he factory wiring remains uncut.
be cool radiator with two huge spal fans, and all the spal wiring.
two 24k trans/engine oil coolers
an untouched stock harness for the truck.
can include the bbc brackets and accessories
was thinking of selling with the stock rims at the 3k, but have 18x8 and 18x10 inch torq thrust 2's (the custom order sizes) wrapped with 275 and 305 nitto rubber.
No rust, passenger door lower has a crease in it, hood can use a repaint, clear is coming up.
I'm located in NYC but I can trailer it within 200 miles or so.
hotchkis swaybars
hydroboost brakes
Still available, im at work on my phone but can upload some pics tommorrow
Driver's door does line up, its one click ajar in these pics.
Your results may vary from this depending how much power you put into it.
5.3Caprice
11-07-2015 08:56 PM
lxcoupe
07-21-2015 02:12 AM
