2002 GMC Sportside RCSB Turbo LS1 12K
Odometer 73518 miles. Everything works perfectly on it and the paint and interior is excellent. I would drive it anywhere and it gets around 20MPG on the road. I have raced it at the track 1/4 mile and it had run a best of 11.79@115mph. I have also made 487HP to the rear wheels on a Mustang dynamometer. Here is a list of the mods. Very quiet and smooth ride.
2002 GMC Sierra Regular cab short bed Sportside Pewter exterior Charcoal interior SLE
Power window cruise tilt 5% tint
Denali front conversion with custom grill and Denali projector headlamps
Escalade pewter door handles
SoCal overhead console gauge cluster with Autometer fuel pressure and boost (LED's installed)
2 pod full pillar paint matched with AEM wideband and Areoforce gauges
Tailgate smoothed with handle relocated to the inside
Roll pan
*******'s bed cover
Receiver hitch with 4 flat and 7 wire plug behind rear license plate
2002 LS1 from a camaro
4L65E level5 FLT with Yank 2600 stall
Eaton locking differential
driveshaft loop
Walbro fuel pump
Siemens 60lb injectors (LS1 style with spacers and harness plugs)
Comp Cams Springs
ARP rod bolts
Trick Performance Turbo Kit
T-76 turbo
Airaid intake kit
Nelson Performance intercooler
Nelson Performance tuning no MAF 2 bar HPTuners SD tuning with GM 2 bar MAP
Magnaflow 3" in/out with all mandrel bent tubing rear exit
140 amp alternator
2005 radiator fans with factory harness
2012 GMC Denali Hybrid 18" wheels with almost new tires (less than 1000 miles)
Ipod adapter for factory stereo
Alpine front and Kenwood rear speakers
$12K
Roll pan
*******'s bed cover
driveshaft loop
Walbro fuel pump
Comp Cams Springs
ARP rod bolts
T-76 turbo
Airaid intake kit
140 amp alternator
$12K
bsgiffor
07-19-2015 11:14 AM
