2002 Silverado 1500 HD 6.0L - $3500 (Montgomery)
Finally decided to sell my Silverado 1500 HD. I do not have time to mess with it and already bought a 2009. It is a 1500 HD with the LQ4 6.0L v8 engine and 4L80 transmission. Crew Cab Standard Bed in white. It has 285k original miles.Truck has 8 lug nuts per wheel, heavy duty brakes, and heavier duty axles and suspension than a regular 1500. GVWR 8,600lbs, front GAWR 4,410lbs, rear GAWR 6,000lbs, 5k lbs hitch rating w/o weight distribution bars, w/ load leveler bars 12k lbs hitch rating. Hitch weight w/o weight distribution is 600lbs, with distribution bars 1,500lbs hitch weight. Engine produces 300 horsepower at 4400 rpm and 360 lb-ft of torque at 4000 rpm. Runs strong, no issues with the transmission or drive train. It has a rear cover oil leak. Rear cover kit is $65 and takes about 4 hours to pull the trans, flywheel, and rear cover to replace it. I just replaced some front end components and had the calipers rebuilt not long ago. Also, have custom dual Magnaflow exhaust and newish rubbers and 16" rims with lots of tread left. There is some damage on the bed of the truck where a tree limb fell across it and around the driver fender well where I had a blow out. Other than that the A/C will freeze you out and the interior is clean. It also has provisions for a system under the rear seat, an aftermarket head unit w/remote, and mag mount for satellite radio.. 936 44 three 44 five 8 ask for august..
