2003 ECSB Turbo
2003 ECSB Turbo
This is a Turbo 2003 Silverado 2wd
The truck is in great mechanical condition and fair cosmetic condition.
It has ac, power steering, windows and upgraded stereo system. Selling to fund new project. 13,800 OBO
Tuned to 12psi on E85 for street. Never been to track or dynoed . Should be about 800hp at 16-18psi
Engine:
LQ9 6.0: new cam, rod and main bearings, deglazed cylinders/ 3,000 miles has great oil pressure
Stock bottom end, gen4 rods, jfr cam 214/218@.585, pac springs
oil pump, chain, gaskets etc
Trans: 4l80e 3,000miles,
CK Performance rebuild: new steel, clutches, sensors, billet input shaft, billet forward hub. 1000hp unit
TruCool: 40k trans cooler
Converter: Single Disk Billet converter, Circle D 3400
Turbo Kit: ON3 T4 kit/ Has Next Gen 7875 1.10ar
Fuel: Dual Walbro 450 pumps/ Hobbs switch/ Boost pressure regulator 1:1 ratio
8an feed/ 8an return/ Fast LLC fuel rails/ Snake Eater 142lb injectors
Runs on E85
Gauges: Aem Wideband/ Fuel pressure gauge/ electronic boost gauge/ Trans temp gauge in dash.
Rearend: 10bolt/ Trutrac/ 3.73 gears
Ta cover/ Vas traction bars/ DJM 4/6 drop kit
Exhaust: 4" exhaust, Magnaflow muffler, Cutout
General Grabbers UHP tires
Racing seats/ Custom set brackets
Tuned on HpTuners
Truck is located in Vancouver Wa
Engine:
Runs on E85
Tuned on HpTuners
T-RevMotorsports
04-11-2020 06:11 PM
paco loco
04-12-2019 03:02 PM
