99 Formula built 347 M6 Hardtop
Black 1999 Pontiac Firebird Formula. 6 speed manual transmission. Cloth seats (Grey), monsoon stereo with disc changer, and factory alarm system. Clean Title.
92,3xx miles currently – BUT at 86,000 miles I had the engine pulled and *completely* rebuilt from the ground up. The only things that aren’t brand new on it are the crank, the block, and the external covers.
This is a fully built, forged 347 made (overbuilt) with the kind of premium parts designed to take whatever you can throw at it.
Tagged and inspected
Here are some of the parts and procedures that went into this car:
Parts
GM 243 Heads
Flowtech Custom 228/224 112 Cam
Eaton Hydraulic Roller Lifters
Cometic .040 Head Gaskets
Rollmaster Billet Timing set
ARP Crank bolt
Flowtech custom 3 piece hardened 7.400 Pushrods
FTI spring kit - Hardened Valve Locks, Hardened Spring Locators, Viton Valve Seals, Ti Retainers
JE Forged Pistons
Forged H-beam rods 6.125 x 2.100 x .927
New rings - file fit
New cam bearings
New main bearings
New rod bearings
New main studs
ARP head studs
New gasket kit - Gen III/LS1
GM LS6 Intake
Powerbond Pulley
SDPC LS6 oil pump
Pacesetter Long Tube Headers – coated
K&N FIPK Induction kit
New coolant seals, gaskets, and sensor
New Knock sensor
Transmission serviced w/ Royal Purple
Optima Red Top Battery - brand new
Vat and clean Engine Block
Vat and clean Engine Parts
Bead Blast and Magnaflux Cylinder Heads
Magnaflux & Inspect block, crank, connecting rods, etc
Disassemble, Clean, and set up Cylinder Heads
Resurface/Mill Cylinder heads for added compression
Resurface/Deck Engine block
Bore/Hone Engine block
Clearance Block for rods
Balanced Crank
Cam degreed to ensure proper function
Raptor Shift Light (Red)
Star Stage 3 Clutch + Updated GM Hydraulics and new flywheel (steel)
BMR tubular K-Member + A arms
BMR rear LCA’s
Prothane poly motor mounts
Pro 5.0 Shifter
Lightweight carpet
Custom 3” True Dual exhaust with X-pipe and Magnaflow bullet-style mufflers
ZR1 wheels 17x9.5 and 17x11 new tires
Call or text 682-438-8635
These pictures are taken by my phone. Car is super clean and runs hard.
May be interested in a Lightning, 5.3 or 6.0 RCSB truck. The bike in the picture is for sale also 06 R6s $4,700
http://dallas.craigslist.org/dal/cto/2181976996.html
Parts
GM 243 Heads
ARP Crank bolt
JE Forged Pistons
New cam bearings
New main bearings
New rod bearings
New main studs
ARP head studs
GM LS6 Intake
Powerbond Pulley
SDPC LS6 oil pump
New Knock sensor
Balanced Crank
BMR rear LCA’s
Pro 5.0 Shifter
Lightweight carpet
300zxls1
06-21-2010 09:41 PM
