99 RCSB Z71 LS1-Heads Cam-Built 4L60E-3000 stall. Needs alittle TLC
10 Second Club
I have a 99 Silverado Z71 with 2001 LS1 out of Z28 52k on motor.
Engine: 01 LS1 Short Block with ARP Rod Bolts
Heads: PRC Stage 2.5 5.3 Heads 225cc intake runners with Double Valve springs, titanium retainers.
Cam: Comp LSR 227-243 614-624 lift on a 114. TSP 7.4 harden push rods.
Intake: 2004 EGRless Intake. It was ported at the intake runners to open them up alittle for the heads. It has a stock Ported and Polished throttle body. Also has 42lbs Marine injectors.
Transmission: Out of 2005 silverado 4L60E Beast Sun shell, Kevlar clutches, corvette servos, Trans go shift kit. GM Performance Parts 3000 stall. Has 3:73 front and rear with G80 posi. 4 wheel disc. Has manual transfer case not push button.
2001 Yukon Denali Gauge Cluster. (mileage and Shift Selector doesnt light up)
Has LS1 Fans, Shorty headers with cats removed and a 3" banks Muffler.
Body does have a few dents one is bottom of passenger door and rocker panel and passenger side right on the Z71 decal. I will post pics of them later.
Trucks runs awesome but does need alittle work like dents fixed and roof and hood clear coat fading. But I do have alot money in building the LS1 and 4L60E. Chassis has around 200k on it, LS1 ShortBlock has 55k on it, heads and cam 4k. Trans about 8k. Will come with the Factory 16" rims and tires and a set of BBS 18" with a set of 255/55/18 and a set of 265/60/18. $ 5800 OBO.
I will Post more pics if anyone is interested.
Here is a little idle clip.
