FS/FT 1969 Chevy P/U
I just took these pictures today, I felt that my previous thread for this truck as well as the pictures did not do it justice. Don't mind the fact that its on a trailer, its on its way to get the motor fine tuned.
Frame up restored 1969 Chevy Fleetside long wheelbase
Original two tone paint scheme, dodge viper blue and chevy white
What little rust was on original body was cut out and replaced with metal, no bondo or fiberglass.
Sprayed in bedliner and underneath the entire body to prevent any rust from starting in the future
Original 15X8 rally wheels, new tires
383 stroker, 10.5:1 compression, all ARP stainless 12-point bolts used on motor, heads ported and running 2.05 intake 1.65 exhaust, 1.5 aluminum roller rockers, howards cam: flat tappet 525 525 & 106 lobe seperation, edelbrock performer rpm aluminum intake, jegs sfi certified flexplate, 750 street demon carburetor, super comp Hooker Headers, MSD pro billet distributor, blaster 2 coil, 6AL ignition box, 8.5 msd wires, moroso stroker oil pan (powdercoated silver to match other aluminum on motor), high perf. jegs starter (can handle 15:1 compression), edelbrock performer rpm mechanical fuel pump, weiand aluminum water pump and timing chain cover, 4 core radiator with a 16" electric fan, yellow top optima battery, 2.5 inch exhaust with x-pipe into 2-chamber flowmasters that dump behind each rear tire
TH-400 Tranny, 2500 stall, shift kit, Hurst ratchet shifter
One piece driveshaft, 3.73 Yukon gear with an Eaton posi
Tilt, a/c, tachometer, power steering, power brakes - Loaded!
Converted both front suspension and rear end to 71' year model so I could run 5 lug wheels and have disc brakes up front.
Work needed: seat reupholstered - if you want it to be perfect (has a small crack) & body trim.
The truck has 43 miles since the restoration, I have over 20K invested. I hate to sell my pride and joy but I want to buy a house and I think it would serve better as a down payment than a toy.
I am asking $12,500, I will consider trades..........located northwest of Houston.
PM me for any additional info.
Last edited by HOTRODKEV; 01-09-2008 at 05:23 PM. Reason: Updating current information
14 Second Truck Club
Originally Posted by HOTRODKEV
Cant believe all of these hits and no comments or even a PM. Come on guys.....
